Xerox DC 250 dark banding
  • vishop
    • Jan 2011
    • 220
    Hi guys,
    I have a dark banding (bidirectional) that happens on the prinout. At was very obvious and repeating every 12.5cm (which is the circumference of the color drum having a diameter of 40mm). i tried to shuffle the color drums and even tried to replace each for isolation of problems, still it exist. Tried to clean the ITB assy and tried, it less now but can still be seen. Tried replacement of the belt, not much difference on outcome, but its less obvious now.
    Any ideas where this problem could be? Could it only be in the ITB unit section?
    Thank You.
  • InterfaceP
    • Jun 2013
    • 488
    Re: Xerox DC 250 dark banding
    Can you post a Pic?
