Xerox 7125 error code 116-322
  • slash
    • Apr 2015
    • 20
    I've google only that (earlier models) JBA Account Full RA and I don't know the resseting procedure is the same as 7132.
    The code is 016-322, my bad.
  • slash
    • Apr 2015
    • 20
    Re: Xerox 7125 error code 116-322
    The problem is going on.
    I did procedure:
    1. Press the Setup button
    2. Press the Right arrow button until Tools displays on the control panel, and then press OK .
    3. Press the Right arrow button until Fax Log displays on the control panel, and then press OK .
    4. Press the Right arrow button until Clear Fax Log displays on the control panel, and then press OK . A message that says the fax memory is clear displays on the control panel.
    5. Press the Cancel button to exit.
    Now I have 116-312.
