Error code 009-349
  • kapaz
    • May 2015
    • 11
    Error code 009-349
    Hello
    I have a probleam with Xerox DC2240
    The PWS show in red the error code 009-346 (1st btr retract fault )
    I have tested the retract motor and it works properly.
    I have tested the IBT belt assembly in a similar printer and it works find.
    Any idea ?
    Thank you so much
  • copytech200X
    • 264
    Re: Error code 009-349
    Check the hoisting and lowering mechanism in the IBT ASSY. If hoisting and lowering mechanism shifted, the trouble occurs, even in poor contact between the UNIT and the Drawer in a machine.
    • kapaz
      • May 2015
      • 11
      Thank you once more Copytech.
      Has you can remember , before i had the error 004-346 and 9-933.
      I have changed the IF PWB error 9-933 desappear.
      After do DC 956 -EDGE LEARN MODE- the error 004-346 , also has deasappeared.
      After that this new error 9-349 beguin.
      So you think the probleam is the PLUG that connect the IBT assy with the printer , that has a bad contact ?
      I must clean this pug ?
      The access to this plug is VERY dificult....
      Can i test this connection through the PWS ?
      Other question .. How to do, to test a sensor in DC 330 ? I can see there START and (+) and (-)
