FreeFlow 666s
  • Tmillervt
    • Jun 2025
    FreeFlow 666s
    Looking to see if anyone has tips or tricks to get a Free Flow 665 scanner to operate with the old Digipath Software version 3.0.0.20.
  • xtrain
    • Dec 2012
    • 233
    Re: FreeFlow 666s
    I used to run it on Digipath 2.10. You need the Digipath Color Scan and print software #301E48170 to load on Digipath computer. This has the necessary twain drivers for Digipath to connect to the 665 scanner.
    • Tmillervt
      Re: FreeFlow 666s
      I would assume them the issue is the Digipath software is on a win 2000 machine. Do you have any other suggestions?
      tyia
      also. I have the guts of a Digipath scanner. Is there a way to trick the freeflow into thinking its a digipath?
      • xtrain
        • Dec 2012
        • 233
        Re: FreeFlow 666s
        tyia
        As stated before, you need the 665 drivers installed on the Win 2000 Digipath computer. Also, you need an Adaptec 2940-U scsi adapter installed in the computer to accept the cable from the scanner. The default channel for the scanner is channel 5.
