CREO SPIRE CXP5000 Wrong Disk Configuration Error
  • ericbistudios
    • Jun 2015
    • 5
    I have Installed new hard drive into my creo system. and i keep getting this VBScript Error : Wrong Disk Configuration Run Disk Administrator to Correct.
    I have tried everything that i know i even stripped the drives please see pictures attached.
    Can you help me please?
  • xerotec
    • Oct 2009
    • 45
    Re: CREO SPIRE CXP5000 Wrong Disk Configuration Error
    do not format striped volume
    • xerotec
      • Oct 2009
      • 45
      just create do not format to any file system
      • ericbistudios
        • Jun 2015
        • 5
        Hey Xerotec, Thanks for your help. Ive formatted the drive in the disk management without stripping but i still get the error message. is there a certain way i am suppose to format the drive ? thanks you again for your help i really appreciate it.
        • davidj7
          • 1107
          You have to followthe procedure as mentioned in the installation notes . Its a straight forward procedure once you get hold of the pdf file.
          Edit : The current file system on your disk is NTFS
          a machine is only as good as your tech : source:screwtape ; the scary one
          • ericbistudios
            • Jun 2015
            • 5
            Okay have found the reference material but it is instructing me to initiate disk stripping procedures. will follow these directions to see what it does thank you again
            • xerotec
              • Oct 2009
              • 45
              this s tech manual for creo password is 6789
              • ericbistudios
                • Jun 2015
                • 5
                Thank you i have reinstalled software now able to print but all prints are coming out blue?
                what should i do with this new issue and is there any place i can get ahold of the portable workstation?
                • xerotec
                  • Oct 2009
                  • 45
                  check cable from RIP to Machne
