Transam1
+ More Options
Posts
  • Transam1
    • May 2011
    • 48
    [Misc] Transam1
    I have a xerox 5855 that when you walk up to it and for example select 5 copies is starts spitting out blank pages and wont stop till you shut off the machine.
    Have changed the drum and sep trans wires worked for about a month now problem is back .
    Has anyone experienced this and what fixed it.
  • Exok
    • Jun 2011
    • 750
    Re: Transam1
    Before starting to make any copies, see if you can access the fault history to see if any fault codes are recorded. Report back with what you find. 03-777 codes will appear. They are sudden loss of power errors that will show up due to shutting the machine off in the middle of printing blanks.
