Xerox ColorQube 9203 error code 099-689
  • AJAMS
    • Jul 2025
    I have a Xerox ColorQube, with the error code 099-689.
    Thank someone to help me.
    before I had given the error code 093-872 but disappeared and appeared this above.
    thank you
  • Flash
    • 378
    Re: Xerox ColorQube 9203 error code 099-689
    The 93 code is most likely contaminated ink. Check the ink loader and make sure the right ink is in the proper channel. The other code is for a sensor in the ink melt reservoir. Replacing the ink melt reservoir should take care of both codes.
