Xerox 242 ADF scanner issue, image shifted 0.5"
  • drewzif
    • 101
    [Misc] Xerox 242 ADF scanner issue, image shifted 0.5"
    I have a DC 242 with an ADF scanning issue. When copies are made the image is shifted 0.5" to the left. If i use the flatbed however images print without the shift.
    Is there a way to calibrate the ADF alignment?
    A manual image shift adjustment can be made at the time of copying but I would like a solution to avoid using this workaround.
  • drewzif
    • 101
    Re: Xerox 242 ADF scanner issue, image shifted 0.5"
    I believe there is a mechanical adjustment to be made. Anyone familiar with this?
    • Corder
      • Nov 2014
      • 105
      I believe this machine should have separate registration setup for both flatbed and ADF modes. Usually it can be found in service engineer mode.
      • drewzif
        • 101
        I have been searching the service engineer mode and can't find it, driving me nuts!
        • Exok
          • Jun 2011
          • 750
          ADF Lead edge registration side 1:
          In service mode enter NVM read/write
          711-140 sets this registration. Min=0 Default=122 Max=244. Adjusting this value by 25 points = about 1mm.
          ADF Lead edge registration side 2: NVM 711-141.
          ADF Side registration side 1: NVM 715-110 & 715-272 (change both at the same time, both values need to be the same)
          ADF Side registration side 2: NVM 715-111 & 715-274 (change both at the same time, both values need to be the same)
          • drewzif
            • 101
            Thanks a million Exok! I will give this try tomorrow.
            • drewzif
              • 101
              Worked like a charm! Thanks Exok, sorry for late reply, thought I had updated the post but clearly i didn't!
