WC 5735 help needed!
  • Corder
    • Nov 2014
    • 105
    Hi guys, can anyone tell me to which model line this machine belongs? Cannot even find it in Eureka Snaps DB. Mechanically it is very close to CC 232 but both have different soft platforms as I see. So what node I should check in Eureka when needed, can anyone point to?
  • adriansto
    • 2386
    Re: WC 5735 help needed!
    Look
    • Corder
      • Nov 2014
      • 105
      Originally posted by adriansto
      Look
      Lot of thanks! And so with edoc I suppose? One for 5735 and 5790?
      • adriansto
        • 2386
        One edoc for WC57xx family.
        • Corder
          • Nov 2014
          • 105
          Many thanks, you help me a lot )
          • adriansto
            • 2386
            Welcome !
            • he7060
              • Jul 2015
              • 14
              I have Xerox 5735 with error code 09-597 toner concentration process control has failed .... help
              • adriansto
                • 2386
                Remove developer unit and check toner dispenser gear mechanism and sensor.
                dc09-001 must be on 0. Also good 24 voltage on dispenser motors
                • he7060
                  • Jul 2015
                  • 14
                  i will try it. thanks
                  • MrXerox
                    • Sep 2010
                    • 76
                    There is a small brown gear on the toner dispensor (located on the back of the developer) than get get worn out.
