xerox 8825
  • walidcharifi
    • Feb 2011
    • 379
    xerox 8825
    hi freinds
    i have xerox 8825 display ll-22
    can help ?
  • Corder
    • Nov 2014
    • 105
    Re: xerox 8825
    Originally posted by walidcharifi
    hi freinds
    can help ?
    You have to remove toner from the detack corotron.
    • walidcharifi
      • Feb 2011
      • 379
      Re: xerox 8825
      thanks..
      i remove the toner from the detack corotron .....no result!
      • Corder
        • Nov 2014
        • 105
        Re: xerox 8825
        thanks..
        Are you sure that it was detack corotron and not charge scorotron? Where was the location of corotron that you've cleaned up?
        • walidcharifi
          • Feb 2011
          • 379
          Re: xerox 8825
          1.JPGUnder Drum
          • Corder
            • Nov 2014
            • 105
            Re: xerox 8825
            [ATTACH=CONFIG]29557[/ATTACH]Under Drum
            Did you have the assembly removed? Somewhere must be a huge amount of toner that creates electrical current leakage. And check the charge corotron as well.
