xerox 4110 012-323 error.
  • Tinochka
    • Jul 2012
    • 127
    [Error Code] xerox 4110 012-323 error.
    Urgently need help.
    I have 012-323 error on xerox 4110.
    What means this error?
  • InterfaceP
    • Jun 2013
    • 488
    Re: xerox 4110 012-323 error.
    Associated with the finisher hole punch. If you dont need it for the job your running take it off and run without it.
    If you need I can look for further info, but it's not listed in the service documentation.
    • Tinochka
      • Jul 2012
      • 127
      Can you tell where to look. Or give please more information.
      • Tinochka
        • Jul 2012
        • 127
        Thank you very much. The problem is solved.
        • Meshdrops
          • Nov 2021
          • 3
          Thanks for this. do do think it can also solve error 012 321?
          • Meshdrops
            • Nov 2021
            • 3
            Solved, i found this to be an issue with a broken wire, did a physical inspection of punch harness wires located at back of machine.
