Docucolor 250 showing error code 091-320
+ More Options
Posts
  • alex4alltimes
    • Feb 2010
    • 68
    [Error Code] Docucolor 250 showing error code 091-320
    Hello everyone! My Docu 250 is displaying error code 091-320. Does anyone have the nvm code needed to reset the error? Thanks in advance....
  • Exok
    • Jun 2011
    • 750
    Re: Docucolor 250 showing error code 091-320
    There is no NVM to reset. 091-320= charge scorotron wire is broken. Replace the charge scorotron on the black drum cartridge or replace the black drum cartridge (comes with a new charge scorotron)
    • alex4alltimes
      • Feb 2010
      • 68
      Hi Exok! I have replaced the scorotron and after that also replaced the drum unit, but the error does not go away.
      • alex4alltimes
        • Feb 2010
        • 68
        Another thing I forgot to say. This thing had happened earlier also but the fault went away on its own.
        • adriansto
          • 2383
          Problems on AC Power Supply 24 v line.
          Bad - cold solder joints. Also 24 volts is the power for developer HVPS's and Charge HVPS so check they also for cold solder.
          • alex4alltimes
            • Feb 2010
            • 68
            Thanks for your reply Adrian! I will look into it.
            • Exok
              • Jun 2011
              • 750
              Remove the drum / dv unit tray and inspect the contacts on the back inside frame that make contact with the black drum unit. You probably have a damaged / missing spring contact or the housing around the spring might be broken.
              • alex4alltimes
                • Feb 2010
                • 68
                Yes. That section was the problematic one. Actually the contact point in the scorotron had somehow receded inside. Had to pull it out with pliers. Voila! No error now! Thanks for your support guys!!! (y)
