Is there anybody know how to reset the NVRAM on a Xerox workcentre 7545,if the picture is not coming sharp or if the color is not register and how to calibrate the color
Re: Is there anybody know how to reset the NVRAM on a Xerox workcentre 7545
2. Open 'Adjustments' tab and there on it you'll find 'dC301 NVM Initialization'.
I strictly recommend you to save NVM data before using dC301.You can do it with 'dC361 NVM Save and restore'. First save data on the copier HDD then copy it to usb thumb drive using the same dC361. -
Do you have color to color misregistration? i.e colours put down slightly one after the other instead of all on top of each other creating a sort of ghosting effect?
If this is the case try cleaning the MOB ADC sensor or replacing it, failing this i've installed a new MCU PWB to correct the fault.Comment
