Scan- and eMail-Kit on DC535 - Kit-Number
  • Steffen78
    • Jun 2025
    Hi out there,
    I have got an DocumentCentre 535 and I want to use the scan and eMail-function. In the DC an scan-kit is installed as it shown as in the hardware infomations on the DC - but it is disabled.
    If I want to activate it it asks for a kit-number.
    Do you know what this kit-number is and where I can get it?
    I don't have anz documents, the onlz I have is a diskette on my DC for service purposes but the file on the disk is not human-readable.
    Can anybody help me ... ?
    Thanks and best regards
    Steffen
  • TechMate
    • Mar 2008
    • 285
    Hi there! Scan kits and scan-to-email function usually comes with a SOFTWARE KEY that should be included in the documentation of your machine. The best way to get help is to call/ ring xerox and quote the serial number in order for them to identify the software key that should be in their system at the time of installation.
    • hana_freak
      • Oct 2008
      • 44
      Try this:
      23295855
      or
      10621933
      or
      91003408
      • artphil
        • Aug 2008
        • 155
        Codes....
        Hi Steffen,
        Here you go...
        Scankit A 51973186(scan) 56285600 19881288
        Scankit B 53662331(e-mail) 22429199 26398122
        I think you should be able to enable the options with these codes.
        Or if you want you can always call Xerox as "TECHMATE" explained you
        Kind regards,
        Artphil
        Originally posted by Steffen78
        Hi out there,
        Steffen
        • xcopytech
          • Aug 2006
          • 1792
          Is it possible to use this scan kit numbers also for WCP 35-45-55 machines?
          BR
          • artphil
            • Aug 2008
            • 155
            dnot exangable
            Hi,
            You already guessed it but unfortunately these codes can only be used on the machines I already posted others are completely different and for Sale as many people want them and makes this machines worth a lot more . I sell them for 150 euro's btw
            Artphil
            • surfern
              • Mar 2009
              • 7
              artphil you are the best !!!!!!!!!!!!!!!!!
              Thanx !!!!!!
              Xerox Rulez !!!!!
              • Marc69
                • Goshe
                  • Jul 2009
                  • 118
                  I need 5 digit kit number for DC545 (the network controller is from DC555)
                  • Goshe
                    • Jul 2009
                    • 118
                    Marc69 try with this:
                    A:03175
                    B:58063
                    it should work with DC555/545/535
                    • Marc69
                      Thanx a lot!!!!
                      IT WORKS!!!
                      • fenave69
                        • Jul 2009
                        • 16
                        ok, thank you very much i'll try with this code
                        • ivi0708
                          Hello
                          i used the codes below to enable scan in xerox workcentre pro 45 but i dont know how to configure the scan to file.
                          can anybody help?
                          • fenave69
                            • Jul 2009
                            • 16
                            first you need to install centreware 5.52 on pc , and then give the printer adress and install as smb, create a shared file to intall it, and then should appear on printer the server adress to send scaned documents.
                            • ivi0708
                              thanks a lot
                              thanks a lot, i solved the problem on my own. i forgot to create a ftp server on my pc. i used filezilla server (freeware) to creato a ftp server. anyway thanks a lot for the reply.
                              if can help me i have a problem with my xerox dc 242. i cant configure the scan templates. when i log in to the webtools as admin and click the new scan template it redirects me to a error page. do you know something about this problem??
