firmware xerox phaser 6700
  • mdm
    • Jun 2009
    • 132
    Good morning,
    want to know if any one has any firmware for the xerox phaser 6700?
  • adriansto
    • 2387
    Re: firmware xerox phaser 6700
    What version ?
    • mdm
      • Jun 2009
      • 132
      Thanks for the response, the version I am not sure, initially the 081.140.101.13501 was on the printer, but there was a black imaging unit fault and I found a fix in the firmware. But when I put 081.140.103.22600 the network portion of firmware failed but every other portion of firmware was successful and a report printed that states software upgrade result: success with firmware change from 081.140.101.13501 to 081.140.103.22600. But there is still a imaging unit fault. the imaging unit is brand new.I tried a lower version and got the message that downgrade is not allowed. I tried to reinstall 081.140.103.22600 and got a message uprade not necessary. I want to install a higher version like 081.140.104.05700 or 081.140.103.24600 with hopes that all of the firmware would install without errors or faults and hope that would fix the imaging unit faults.
      I am open to suggestions.
      what is the bridge download zip?
      • mdm
        • Jun 2009
        • 132
        Good Morning Adriansto,
        If I can 081.140.104.05700 and 081.140.103.24600,
        I would really appreciate it.
        • mdm
          • Jun 2009
          • 132
          Hi guys I am desperate and hoping some one has a solution that can help solve this problem.
          • vic4we
            • Mar 2023
            • 15
            Hope this was solved
