Nuvera 120
  • Dfriis
    • Feb 2014
    • 31
    Nuvera 120
    If someone put EA toner in a nuvera MX 120 do you have to do a developer change? Or can you just clean the hopper and go?
  • Milo Wilson
    • 502
    Re: Nuvera 120
    How many prints were run with the EA toner? You will probably need to dump developer and put new MX developer in if it was a lot. Otherwise you can just run however many sheets to detone the developer ( remove the toner before doing this) and when it is as purged out as it can be, just add MX toner and retone the system.
    • Dfriis
      • Feb 2014
      • 31
      Re: Nuvera 120
      Milo, Thanks for the help. We have emptied the hopper and cleaned it all out and the toner add unit also. So there should only be what got in the developer left. I think we will try just running it out and see if it work to save the developer. It was just done 3 weeks ago.
      Thanks again, Don
