Toner control system failure
  • t.jeevanantham
    • Apr 2015
    • 3
    [Error Code] Toner control system failure
    Sir,
    My Xerox Workcentre 5790 machine showing error message when switched on the machine like toner control system fault with power down and ignore error message. kindly help me to solve this error
  • Lijodamodaran
    service manager
    • Sep 2014
    • 56
    Re: Toner control system failure
    go to service representative mode select copier routines xerographic control 09-069 check value...if its default check devoleper assy.
    • adriansto
      • 2386
      You need to remove developer assy and check the gears and sensor from dispenser assembly.
