Risograph TR error C21 master won't load around the drum
+ More Options
Posts
  • austinlonz
    • Aug 2015
    • 15
    I recently just purchased a risograph TR1510 an error saying a jam in the master roll area keeps appearing. When i look in and check the master is just barely poking out the on the side the master disposal area is. When I hit the star it says C21. Very new to Risograph
  • Iowatech
    Not a service manager
    • 3930
    Re: Risograph TR error C21 master won't load around the drum
    C21 is the error code for the master not being applied to the drum.
    It would probably be a good idea to reset the machine if you haven't done so first, then make sure all the sensors in the drum cavity are clean.
    I can't see your machine or what you've done so far, so that's just a wild guess.
