Riso GR3750 Empty Disposal Box error
  • cokwax
    • 50
    This error started being persistent on my GR3750 even after actually emptying the disposal box and setting it in place. I have tested continuity of the sensor wiring and all is well. I swapped the sensors from another machine and problem persisted. I would like advice or any quick error clear fix that can get the machine running while I try ordering for a new set of sensors.
  • Iowatech
    Not a service manager
    • 3930
    Re: Riso GR3750 Empty Disposal Box error
    If you haven't tried already, start by resetting the machine - turn the machine on while holding down the "Reset" key on the control panel, and continuing to hold the key down until the initializing motor sounds get quieter.That will reset the machine's working memory which can solve a lot of odd problems.
    I'd recommend running at least two new masters and around twenty prints next.
    If the machine works after that, it is fixed, no need to order parts.
    There is one sensor involved with the "empty disposal box" message - it looks through the box to make sure there are no masters remaining. If you look at the disposal box there is a hole in the top that lines up with a hole in the bottom, make sure those holes are not obstructed. Also if you can find the part of the sensor that lines up with the hole in the bottom of the box, make sure it is not obstructed by dust or something.
    Hope that helps.
    Last edited by Iowatech; 09-24-2015, 01:26 AM. Reason: Almost forgot about the one sensor.
