Help me remove screen from GR3770 Drum
  • ciscoram
    • Jan 2016
    • 6
    Newbie here - just bought a GR3770 today and trying to clean out the gummy drums.
    Question: How do I remove this piece? See picture.
    Any other tips would be great, too. Cheers!
    Frank
  • khobo1
    • Oct 2016
    • 14
    Re: Help me remove screen from GR3770 Drum
    hey frank, if it works anything like my standard SD630 it's more of a long bar clamp that holds the master onto the drum unit. you can clean the inside of the pinching mech with a very damp cloth and maybe some soap (someone correct me if I'm wrong) emphasis on damp. the important point is not to use rubbing alcohol or something inside the clamping mech. again i'm basing this off my sd630.
    GRDrum.jpg[/QUOTE]
    • LA TECH
      • Sep 2010
      • 91
      [ATTACH=CONFIG]31655[/ATTACH]
      [/QUOTE]
      you need a 5.5 m screwdriver like the one in the pic
      • ciscoram
        • Jan 2016
        • 6
        Cool, thanks. I was able to get it apart and clean it. Works much better :-)
        you need a 5.5 m screwdriver like the one in the pic[/QUOTE]
