gestetner 5490+
  • justanick
    • Jul 2025
    gestetner 5490+
    Hi i have a gestetner 5490+, and the drum is stuck and it wont come out, is blocked.
    there is a way to unblock it ? a manual relase ?
    Thank you so much
    Any help will be greatly appreciated
    than you
  • justanick
    Re: gestetner 5490+
    Thank you so much
    ps here is a photo of the unit.[ATTACH=CONFIG]32072[/ATTACH]
    than you
    No one has a tip ?
    Thanks a lot in advance
    • Iowatech
      Not a service manager
      • 3930
      Re: gestetner 5490+
      While I have only worked on Riso duplicators, I do have a suggestion. However, please take it as possible nonsense as I've never worked with Ricoh based duplicators.
      That being said though, it sounds like the drum on that machine is not at home position. On Riso duplicators at least the drum is not perfectly cylindrical, and if the drum is pulled out when it is not at home position damage can occur. As such, you may need to find a way to manually rotate the drum to home position before it can be released.
      If you choose to take this course of action, I do have one warning that you need to be aware of. At least on Riso equipment, there are many sharp edges and strong springs that can harm someone who doesn't pay attention. So please be careful.
      • justanick
        Re: gestetner 5490+
        Thank you Iowatech
        I will try to rotate manually - if i remember correctly is possible - and i wil let you know.
        Of course i will be extremely careful.
