Taking apart non working RP3700, which parts are worth keeping?
  • Philh
    • Dec 2011
    • 27
    I am in the process of dismantling a RP3700 which has under 1 mill copies but had error codes. I replaced this with another RP and would like to keep some of the parts from the old one, like boards, small motors etc., in case the new one needs parts. As I don't have a lot of room I would appreciate advice on what parts would be most useful to retain.
  • Iowatech
    Not a service manager
    • 3930
    Re: Taking apart non working RP3700, which parts are worth keeping?
    If possible, could you let us know what the error codes were?
    I guess without knowing that, I'd still keep the feed rollers and the sep pad if they weren't in too bad of shape. Then again, Riso said they would last for 500K prints, so your mileage may vary.
    • 20gaugeO/U
      • 557
      TPH and Main Motor Drive Gears (3) if they are the dark colored type (don't remember if they were hardened plastic or metal, both they aren't white)
      • Iowatech
        • 3930
        I think I've still got the tech pub about the gears, give me a couple of days and I'll see if I can find it.
        • reignbear
          • Jun 2014
          • 16
          looking at the tech bulletin, the old main drive gears are all 3 black plastic and the new ones are 2 smaller metal gears and one large white gear. I'd also be curious as to what the error code are, they don't really mean the machine is hopeless. on my RP 3700 i've worked my way through at least a dozen (conservative estimate) different error codes over the years.
          • Philh
            • Dec 2011
            • 27
            Re error codes. Started out with T17 020. Nothing jammed in unit but fuse kept blowing. Many more codes followed after this but I can't remember them.
            • Iowatech
              • 3930
              Master/copy counter disconnect error plus a 24v short, tough one that. If the fuse blows with the CN7, 8, 11, 12, and 13 disconnected on the front drive board, the front drive PCB is probably toast. Otherwise the counters or one of the motors might be bad.
              Either way, some parts to take off the list.
              (Sorry, removed connector numbers not related to the 24v B supply, which is the one that powers the counters among other things)
              • Iowatech
                • 3930
                For what it is worth, here you go - I knew I'd shared this tech pub before. Sorry for the delay.
                21158.pdf
