RZ220 to Macbook Pro
  • slimy
    • Feb 2016
    • 26
    [Misc] RZ220 to Macbook Pro
    I was told that even with print controller and network card, i wont be able to connect to any computer newer than a windows 98 on a risograph rz220 because of driver issues?
    i'm looking into trying to connect a macbook pro and was wondering if that would be possible at all or is this going to be a lost cause?
    thanks!
  • VENRISO
    • Jul 2015
    • 72
    Re: RZ220 to Macbook Pro
    hi look in this site and search your driver
    RISO Download Center
    • laitang
      • Nov 2012
      • 627
      Check RISO download driver web:
      Code:
      http://download.riso.com/dl/dlpage.jsp?sitecode=gl1&pagecode=pdall&param1=RZ+series&param2=none&submit=Search
      May it help!
      • CompyTech
        Super Tech
        • Feb 2011
        • 706
        I set up an RZ machine on the network for a client a couple years ago.. I don't normally work on Riso, as our Riso guy at the time was "old school" and did not do any network related stuff. Short story long, I got it to work on XP and Win7.
        As for the Mac... Good luck because I don't believe it's even supported period.
        • jermyth
          Riso dude
          • Mar 2011
          • 441
          Yes if you have all the components installed you can print with Mac up to ver 10.11 and Windows 8. Go to www.us.riso.com, click customer support, click technical support, click download print drivers. Choose model and language. Big list of driver choices.
          Good luck.
          • slimy
            • Feb 2016
            • 26
            Good luck.
            thanks! that was really helpful
            • onlygreatcopiers
              • May 2011
              • 41
              Good luck.
              Here is the link:
              Good luck!
              • jhyun03
                Where can you purchase the printer controller/network card for the macbook? Hope you can you help, thanks!
                - CL
                • thibaut
                  • Mar 2017
                  • 23
                  thanks!
                  Every has been said here but with Mac I had issues and I also helped a friend with a RZ. When everything was done (drivers installed), sometimes in direct wire connection it just does not work. The best solution is to use your Riso as a network printer, via your router.
