Vertical Lines/Weirdness with Riso MZ 1070
  • yoamomonstruos
    • Jun 2025
    [Misc] Vertical Lines/Weirdness with Riso MZ 1070
    Hey everyone,
    I'm really new to working with Riso machines. I was wondering it someone could help me out with some advice. I've recently purchased an MZ 1070e and after trying to run some test prints I'm getting the following results:
    so what I'm stuck with is:
    1) What is causing the vertical lines? Is this some issue caused by the rollers?
    2) What is causing the wavey/distortion in the top left of the black print?
    Any help is much appreciated.
    Cheers
  • 20gaugeO/U
    • 553
    Re: Vertical Lines/Weirdness with Riso MZ 1070
    Black Drum - make a confidential master then pull the drum out and run your hand over the drum surface. Is it dented???
    Lines - clean the TPH with a soft cloth and ISO Alcohol. Make a master using test mode 80. Lines still there??? I can't quite tell if the lines look like TPH going out or drums screen/shell needs to be cleaned.
    • Iowatech
      Not a service manager
      • 3930
      I would be inclined to say the TPH is responsible for the lines, as under magnification the pattern of lines is remarkably similar between the two pictures.
      Hopefully cleaning it like 20gaugeO/U said will take care of that problem, as the TPH is pretty expensive.
      • pj4nh
        • Sep 2013
        • 64
        Originally posted by yoamomonstruos
        Hey everyone,
        [ATTACH=CONFIG]32669[/ATTACH][ATTACH=CONFIG]32670[/ATTACH]
        Cheers
        1 - Vertical lines:: agreed with last two posts, must be TPH... where are you located? My Tech might be able to get you a replacement.
        2 - Distortion:: your drums are dented >> you can replace the drum body or live with the dents.
        good luck & welcome to the riso-world, I've been a big fan of Victory Magazine... We publish a satirical magazine called, SPRTS. Maybe see you around the art-book fairs.
        -PJ
