can i fit my ez220 TPH unit into damaged rz220
  • charlzz_90
    • Sep 2015
    • 44
    [Misc] can i fit my ez220 TPH unit into damaged rz220
    hi all, can a TPH unit of ez 220 be used to replace the damaged TPH unit of a rz200 machine?
    The connectors seem fit.
    Thankyou for your consultation.
  • VENRISO
    • Jul 2015
    • 72
    Re: can i fit my ez220 TPH unit into damaged rz220
    greetings friend, my technical experience are basically the same machines, you may also say that if the connectors are the same, probably because the machines use the same tph, the rz200 and EZ200 they have the same resolution, that means using the same TPH, just remember do ajutes voltage when riding or change the THP.
    • jermyth
      Riso dude
      • Mar 2011
      • 440
      Riso parts manuals say they are not the same, different part numbers.
      But if you're will to deal with possible other problems if it doesn't work out, boards going out, go ahead and try.
      Good luck.
      • charlzz_90
        • Sep 2015
        • 44
        thank you for your sharing, Mr.VENRISO. Really appreciated that.
        • charlzz_90
          • Sep 2015
          • 44
          Good luck.
          very huge risk to take. as the item is very costly. anyway thatks for the early precaution.
