Riso RZ 300ep drum says "no ink" but it has.
  • Inko Press
    • May 2016
    • 11
    [Misc] Riso RZ 300ep drum says "no ink" but it has.
  • _SuabE_
    • Jan 2008
    • 108
    Re: Riso RZ 300ep drum says "no ink" but it has.
    Check your ink pump, and ink hose it is clogged or the ink supply outlet inside the drum is clogged. If you noticed it will keep on initializing the ink then it will stop then, giving a no ink indication.
    sigpic
    Senior Technician Specialist
    A+; Network+
    Copier Brand handled: Canon, Lanier, Konica Minolta, Sharp, Ricoh, Kyocera Mita, Nashuatech, Ollivetti, Toshiba
    Printer Handled: Canon, HP, Epson, Brother, Samsung
    Duplicators: Risograph, Duplo
    • Inko Press
      • May 2016
      • 11
      • pj4nh
        • Sep 2013
        • 64
        you can find the technical manual at qmanuals.com
        try the test codes to activate the ink pump.
        also try reprogramming the drum
        codes:
        117
        start
        clear
        890
        start
        best of luck
        • Inko Press
          • May 2016
          • 11
          codes:
          117
          start
          clear
          890
          start
          best of luck
          Thank you for your answers,
          as i can see test mode only works without the ink cartridge, when the cartridge is on, only 0000 appears on the screen. i have tested the codes and no good news.
          The machine says that there are two errors:
          C01-512 The ink sensor did not go ON even when inking was performed for a preset duration
          and
          C01-563 Ink remaining amount is zero from the information on the RF-Tag
          any advice? Thank you!!
          • Inko Press
            • May 2016
            • 11
            Finally, a new cartdrige arrived and everything runs ok at it seems....Thank you all.
