RZ200ep
  • Abimotek
    • Feb 2015
    • 59
    [Error Code] RZ200ep
    What could be problem my RZ 200ep, while printing it will suddenly stop, after i press star code C01-512 shows, pls solution
  • _SuabE_
    • Jan 2008
    • 108
    Re: RZ200ep
    ink sensor cannot sense the ink, check ink or ink sensor, or ink is blocked even inking has performed
    sigpic
    Senior Technician Specialist
    A+; Network+
    Copier Brand handled: Canon, Lanier, Konica Minolta, Sharp, Ricoh, Kyocera Mita, Nashuatech, Ollivetti, Toshiba
    Printer Handled: Canon, HP, Epson, Brother, Samsung
    Duplicators: Risograph, Duplo
    • Abimotek
      • Feb 2015
      • 59
      Re: RZ200ep
      Pls which of the ink sensor, have tried different inks same error C01-512, some times after printing 20 pages or more,i will unlouck then lock ink, to dictect ink back. number 3 and ink light shows.
      • jermyth
        Riso dude
        • Mar 2011
        • 440
        Re: RZ200ep
        The ink is got getting to the ink antenna inside the drum. Possible causes: ink pump not pumping or clogged, ink distributor clogged, one-way squeegee gear slipping. Try running the ink pump in test mode, 882, do you hear it pump? If now then you need a new pump. No matter what it sounds like you need to open up the drum to see what's going on.
        Good luck.
        • 20gaugeO/U
          • 557
          Re: RZ200ep
          Or your amazing knock off ink and masters aren't all that great
          • Abimotek
            • Feb 2015
            • 59
            Re: RZ200ep
            Thanks after i did pump test mode, we make nonthing less than 400 hundred copies, no number 3 light, on like then before hundred it will stop
