riso 220 Drum Problem - T96-569
  • itay
    • Aug 2025
    [Error Code] riso 220 Drum Problem - T96-569
    i replaced the color in the drun and then i got this error
    i saw this guide
    1. Insert Ink Catridge to drum i did it
    2. Switch on the machine and enter the test mode (Do not insert drum to the machine) ok
    3. Insert Drum to the machine pres Reset key if error appear ok
    3. Enter test Mode 117 and start after that i click on the start its changed to automatically to end
    4. Enter test mode 890 and start after that i click on the start its changed to automatically to end
    5. Enter test Mode 887 and start its start make some noise ' after one min its stoped i turend of the machine opened her again and i still got the error T96-569
    what can i do ?
  • VENRISO
    • Jul 2015
    • 72
    Re: riso 220 Drum Problem - T96-569
    hello a question the ink tube you're using is original riso ? because with the generic cartridges can not reprogram I drums, second I always use the code 890 and then the code 887 for inking
    • VENRISO
      • Jul 2015
      • 72
      you can try this form 1_entras in test mode with the drum inside the machine and the front door open and ink to set out 2_ place the code 890 followed you enter the ink, if an error occurs pressures reset and you put 890 and star , you verify that no error , raisins to 887
      • VENRISO
        • Jul 2015
        • 72
        finally check that the ink tube has chip
