RZ990 Drum stuck in machine
+ More Options
Posts
  • CCC Repair
    • Sep 2014
    • 47
    I have a customer that has an RZ990 that quite often, the press roller is in up position preventing the drum from being removed from the machine. I have to manually rotate cam to lower press roller. I have made the press roller adjustment (mounting position of pressure lever on page 7-10). I have not taken the main drive out to examine it yet but was wondering if possibly a gear is stripped or hair-line crack? I hesitate doing that until I have exhausted all other scenarios. I can run it like a charm for several hundred pages then it stops with jam and press roller in up position again. Any thoughts? Thanks
  • Iowatech
    Not a service manager
    • 3930
    Re: RZ990 Drum stuck in machine
    It's pretty unlikely there is a cracked gear if the pressure roller position is the only problem. I'd be focusing on the operation of the solenoid and the pressure lever if it was me working on that machine. Make sure there's no burrs on the pressure lever and the lever on the solenoid where they connect, and make sure the return spring on the solenoid is in good shape.
    Might not hurt to do the first level of resetting the machine, too. It's service code 110 if I remember correctly (don't have manuals right now, sorry), or you can do pretty much the same thing by holding down the "Reset" key while turning the machine on, and holding the key down until the initializing motor sounds get quieter.
    Good luck, and let us know how it goes, please.
    • CCC Repair
      • Sep 2014
      • 47
      Thanks... I actually forgot about the solenoid issue. I know GR's had that issue quite a bit but never ran across RZ's with that issue but it has also been a couple years since I have worked on any RISO too. I already tried the reset and of course that didn't work. The solenoid could possibly be the problem. I'll check it out. Thanks again.
      • pj4nh
        • Sep 2013
        • 64
        I think code 866 is the drum unlock code?
        885 is to turn the drum lock solenoid on/off
        886 is to turn the pressure solenoid on/off
        first code should do something and then just make sure the drum is in its home position before removing it entirely.
        good luck
        • 20gaugeO/U
          • 557
          You never truly know everything they addressed with Firmware. The latest is
          RZ9 Print Engine Program Ver. 2.23For more information see PIN 30092
