Hi guys,
Need some advice.
I have a Riso 590u that stopped feeding through 2nd part of machine, right before drum. The machine will feed till paper is about 3/4 inside machine, then gets stuck for a second or 2, then goes through machine, followed by a paper jam error. It happens every time now.
I have the repair manual. I've adjusted the table height sensors, cleaned the wheels etc. It seems to feed just like always.
I also checked the timing marks running the machine at 30 rpm in test mode. Looks like the 2 timing marks are lined up perfectly every 3 rotations for the big gear. Machine looks and sounds like normal when running.
So what should i look at next? Clutch etc.
Thanks in advance for your suggestions!
Brent
Need some advice.
Brent
