How to program a risograph RZ220 drum
  • rrbilly1
    • Jul 2025
    Does anyone have step by step instructions for How to program a risograph RZ220 drum. The drum is brand new right out of the box.
    thanks
    rodney
  • VENRISO
    • Jul 2015
    • 72
    Re: How to program a risograph RZ220 drum
    Print Cylinder (Drum) Preparation
    1) Remove three Shock absorbing blocks from the Print cylinder (drum).
    2) Insert an ink cartridge into the Print cylinder (drum).
    Lead ink to the nozzle of the cartridge in advance.
    Important !
    Be sure that the Print cylinder (drum) temperature is above 59 F (10 C).
    3) Plug the power cord of the printer and start up the test mode.
    Important !
    Be sure that there is no Print cylinder (drum) installed in the printer at this point.
    No.d04-534No. 117No. 890No. 887NOTE No.8872. Operation Check
    1) Make a master with Riso test chart No.8 and print 200 copies at speed 3.
    2) Check density balance and if necessary, re-adjust the gap between Squeegee roller and Print cylinder (drum) body.
