Riso GR 3750 Clamp Motor Issue / T3 Error
Tags: None
Re: Riso GR 3750 Clamp Motor Issue / T3 Error
The problem seems to have been solved.I removed the clamp motor unit, cleaned it up and hit the motor shaft and bearing with white lithium grease, and reinstalled. I also lubricated the angular magnet plate gear on all drums. Everything appears to be running properly again. -
The problem seems to have been solved.I removed the clamp motor unit, cleaned it up and hit the motor shaft and bearing with white lithium grease, and reinstalled. I also lubricated the angular magnet plate gear on all drums. Everything appears to be running properly again.Comment
