I just had an EZ221 shipped to my country (iceland) and am starting it up for the first time. After seeing the label above the AC inlet indicating both 220-240v / 100-120v (and reading in the manual to not touch to power switch which is the tiny hole with a white line inside above the inlet) I plugged it in, turned on the power and got zero response from the machine. No noise, no lights, nothing. Upon closer inspection I saw that it was possible to switch the setting of the white line in the power switch, moved it to the left to situate the line above the 220-240v side, plugged it in again, tried the power switch and got no response. I am thinking it may be possible that a circuit breaker may have been broken - does anyone (especially international people) have any experience or insight with this? Or perhaps a connection with a risograph technician that I can call?
Thank you so much!
G
Thank you so much!
G
