Riso Comcolor 7050 - Error Code S98-1801-3
  • andy_g
    • Jul 2025
    [Error Code] Riso Comcolor 7050 - Error Code S98-1801-3
    Hello,
    I wonder if anyone can help as this has just about driven me to distraction. We keep getting the error code S98-1801-3 on a Riso Comcolor 7050. It starts up OK and then once it starts printing it will stop and display the code, there is no set amount it will print before it throws up the message, it can be 500 sheets or sometimes 40 sheets but I will say that the larger numbers now happen less and less.
    If anyone can shed any light on this I would really appreciate it
    Cheers
    Andy
  • Sriyanjan
    • Apr 2015
    • 79
    Re: Riso Comcolor 7050 - Error Code S98-1801-3
    S98 must be hardware error
    Sent from my HTC Desire 820s dual sim using Tapatalk
    • Sriyanjan
      • Apr 2015
      • 79
      1801-3 cyan RFID tag module Communication error.
      • Sriyanjan
        • Apr 2015
        • 79
        Check cyan ink cartridge.
        • andy_g
          Thank you very much for getting back to me, I have removed the cyan cartridge and put it back in, it is now coming up with the error straight away and will not print anything. Could it be something to do with it not communicating with the chip in the cartridge? Can you get a weak signal or something like that?
          Thank you very much for you assistance so far, it is much appreciated.
          • Sriyanjan
            • Apr 2015
            • 79
            What about ink cartridges genuine or compatible*ink cartridges?
            • andy_g
              The initial problem came about trying to use compatible ink where you refill and change the chip. However since my last message I have been able to try several new chips that are confirmed as working but still do not work. I have also been able to try a new genuine cartridge and it registers there is a cartridge in the machine but only for a few sheets before the same error code comes up. Its like the machine is struggling to see the chip or they are in and out of range.
              Once again, your assistance is much appreciated.
              • Bhenz19
                • Dec 2016
                • 8
                Hello I have also a problem with riso comcolor 7050 and it gives me code S01-1132
                I hope you could help me guyz
                • hasan5900
                  • Dec 2015
                  • 13
                  pls code error riso comcolor s35-2076-2
                  I know that the error in the yellow color I want to solve this error please pictures or video
                  This is my number 009647703194330
