Risograph GR3750 T3 error message
  • patrus
    • Feb 2017
    • 5
    [Error Code] Risograph GR3750 T3 error message
    I am getting a T3 error message and want to reset it.
    We had service tech come and do service call on the machine, it worked fine. We moved the machine 20 feet from one room to another and now we are getting an T3 error message.
    Suggestions please
  • 20gaugeO/U
    • 553
    Re: Risograph GR3750 T3 error message
    Always start with the yellow Reset key
    T3 - Clamp Error The silver metal piece on top of the drum that holds the master in place.
    That machine is OLD, important parts very very scarce. There are many threads on this machine style (RA/GR/FR are practically the same) and topic for your reading pleasure. Got a manual???
    • patrus
      • Feb 2017
      • 5
      Thanks for your help, we will give this a try.
      • filmplane
        • Nov 2014
        • 84
        Here is the direct download page for the Technical Manual for the GR3750:
        Search
        Select GR as "Series" and Document Type "Manual" from the drop downs and the GR-RA Tech Manual is there in all its glory. Very helpful for troubleshooting issues and understanding various error codes and the machine in general.
        • patrus
          • Feb 2017
          • 5
          Search
          Thanks for the information - I will give that a try.
          • filmplane
            • Nov 2014
            • 84
            Sure thing! Please post an update in the forum if you can. It helps other forum users if you follow up with the steps you went through to solve the issue. Thanks!
