Hello,
which switch is activated, besides the drum-safety switch, upon installing a drum in a RP 3790?
I'm trying to locate this switch to check why my drums are not installed correctly.
The printer only recognizes a drum after a switch sound identical to and as loud as the sound of the scanner-table switch and it comes from the front side underneath the master making unit. (Check pictures)
I have had this problem before:
http://www.copytechnet.com/forums/di...hlight=rp+3790
and for a long time it disappeared after having positioned the drum-safety switch deeper into the machine (towards the back).
But now it came back suddenly without any change to the drum-safety switch - I've checked it's position and I can hear that (quieter) sound when pulling the right side of an installed drum slightly backwards. When I let go the drum-safety switch 'clicks' again.
So, what is this other switch that is so important to recognize and install a drum?
Any help will be greatly appreciated.
