Riso RZ 970 master disposal error, problem with one drum
+ More Options
Posts
  • thibaut
    • Mar 2017
    • 23
    #16
    • s817
      • Aug 2013
      • 13
      #17
      Re: Riso RZ 970 master disposal error, problem with one drum
      try replacing the clamp unit assy , I have had many fail and the symptoms are as you describe especially where the master tears
      in half , ( normally the front half of master is still under clamp plate ), and yes it can affect different drums to differing degrees
      and can be intermittent
      good luck
      • thibaut
        • Mar 2017
        • 23
        #18
        Thanks for your last suggestion s817. I have another problem very different I got to fix, but in the next days I have to test a new drum !
        Since one month, I've had NO problem at all but my drums still have the tape on them. I think, right, it's something very subtle and unclear from the clamps...
        • jermyth
          Riso dude
          • Mar 2011
          • 440
          #19
          If you look at the pictures 20gauge posted earlier the ejection plate is sticking to base and the base needs either smoothed out or as in the first picture cut off.
          Good luck.
