hi all, Ive been out to Ricoh priport 1215 duplicator and the language has changed to Japanese, anyone know how to set it back to English, I have the manual for this model I need to set the display mode to 1 but doesn't say how to get into service or the actual SPcode to get to the display mode, any help would be much appreciated
ricoh priport 1215
Re: ricoh priport 1215
Service Program Mode Access Procedure (For Engineers)
All service program modes can be accessed with the following procedures.
Press the following keys on the operation panel in the following order:
- Method 1 -
Clear Modes ⇒ 1 ⇒ 0 ⇒ 7 ⇒ Clear/Stop
*: Hold down the Clear/Stop key for more than 3 seconds.
- Method 2 -
Clear Modes ⇒ Clear/Stop ⇒ Economy ⇒ Enter (#)
*: For the China machine, use the Combine 2 Original key, instead of the Economy key.
- Method 3 -
Turn on the main switch while holding the Start, Clear/Stop, and Enter (#) keys simultaneously.
NOTE: Method 3 is a special way to enter SP mode that differs from the other two methods. For example, when a service call indicator (E-xx) is displayed at power on, SP mode can only be accessed by Method 3.
After you enter SP mode with Method 3, you can leave it by turning the main switch off then on again.
