Risos and the pressure system
  • thibaut
    • Mar 2017
    • 23
    I check and apart from 3mm the whole absorber is, hum, totally exploded.
    So my question is, as I donโ€™t really know how much the absorber is vital for the pressure system, do you think it can be the explanation of my problem (pressure roller stuck on high position?)? thanks!
    I am currently cleaning all the mess from the absorber. I think I am good for a new one, eheh.
    Also, I am trying to adjust the position of the pressure lever, is it possible without drum in the machine?
  • jermyth
    Riso dude
    • Mar 2011
    • 441
    Re: Risos and the pressure system
    Yes you need the absorber that is the cause for the drum removal problem.
    I'm pretty sure you need the drum, with a confidential master on, to do the pressure adjustment. That should be in the manual.
    Good luck.
