We looked at a RP3700 that was having a problem with a home position code I believe with 1 drum. They have 2 or 3 other drums that worked fine.
Working on the drum with the problem- used drum customer bought- it was put back in the machine and then the separator hit the clamper causing a timing issue.
Our tech says he retimed it mechanically and tested position A and B and they were ok.
When releasing the drum now it is not locked in position and can not be re-inserted. He has to move it like 3/4 counter clockwise to reinsert the drum. The male part of the
drum appears to be 90 degrees out of phase with the female part.
When printing only about 6" appears of a 11 x 17 print.
