Rp3700, roller identification?
  • rking15
    • Mar 2017
    • 16
    I have a roller in my machine that has severely decayed and probably should be replaced. No idea what this is for orwhat to call it. IMG_3342 copy.jpg
    Re: Rp3700, roller identification?
    Originally posted by rking15
    I have a roller in my machine that has severely decayed and probably should be replaced. No idea what this is for orwhat to call it. [ATTACH=CONFIG]37357[/ATTACH]
    the parts manual doesn't have it listed .. or maybe an assembly contains it?
    • jermyth
      Riso dude
      • Mar 2011
      • 439
      The part is called the separator collar. It is part of the separator assembly. Unless the Sep finger is rubbing on the drum I wouldn't worry about replacing it. FYI part number is 030-15113-102.
      Good luck.
      • antoniovs
        • Nov 2016
        • 12
        Here is the PDF of the parts for further information
        media.riso.com/TECH/RP/Parts/4622972.PDF
        • Tan & Loose Press
          Good luck.
          I'm having the same problem. The collar has completely deteriorated. It looks like the rubber has melted and starting to is build up on the rims of the drums. Have you ever heard of something like that?
