ComColor 9150
  • AlbertK
    • Jul 2014
    • 90
    ComColor 9150
    Good day guys
    I am having problems with a ComColor that is printing blank lines through the images.
    It stated with lines across all the images, colour and mono and after normal and a few strong cleaning sessions the colour images seem to be fine however the mono prints still shows light/blank lines in the print direction.
    I know these print heads are expensive and thus I have not tried any other method of manual cleaning.
    The machine is not even a year, the counter is at about 96 000 prints and we only supply original inks.
    Any advise ?
    Thank you in advance
    The product may be brilliant and the salesperson proficient, but if the technician isn’t efficient, then the story will end there.
  • AlbertK
    • Jul 2014
    • 90
    Re: ComColor 9150
    Hey...
    Never mind. We managed to solve the problem.
    Thank you.
    • MadCityCopy
      ieeeee
      • Oct 2010
      • 58
      Re: ComColor 9150
      What did you find?
      Yes very expensive unit. Usually a very solid running machine. During training I believe the instructor mentioned using a magic eraser for the print heads for gentle cleaning.
      • AlbertK
        • Jul 2014
        • 90
        Re: ComColor 9150
        Oh Hi..
        As you mentioned, we used the "special" cleaning solution on the heads. Ran the deep clean about x3 and it was fine.
        Thank you for the interest.
