Riso RZ970 Paper Jam on printing area, every time
+ More Options
Posts
  • thibaut
    • Mar 2017
    • 23
    http://www.copytechnet.com/forums/di...25=#post556681Paper-ejection sensor was OFF when paper should have arrived, and the paper sensorwas OFF when the machine stopped (paper jam on the print drum).
    So I tried to modify some TM to delay the OFF timing. Like TM742 (
    Paper-feed-clutch OFF angle ), TM748 (Scraper Clutch OFF Angle), TM753 (Paper receiving jam detection angle. (Paper IN)), and it seems (for now) to work, EXCEPT after the making of a new master, it paper jams every time.
    I have to say I guess something is around a bad timing on the machine. But if you have some guesses... I just feel my parameters adjustments are not a long time solution.
    Thanks!
  • Paco Telescopios
    • Nov 2017
    • 20
    Re: Riso RZ970 Paper Jam on printing area, every time
    Hello,
    Please excuse my bad english.
    I had this problem in my Rp3700 some weeks ago. The pickup roller and the feed roller took the paper ok, then it seemed to stop in the second feed section which caused it to bend, and then a jam error.
    It happened only at the reversed face with a light type of paper that previously had worked without any problem (+400 sheets printed one face)
    Adjusting the first feed section did nothing; it worked ok
    I seemed a problem of paper detection, but test said ok. I cleaned the paper sensors with no success
    Check timing and seemed ok (maybe not, I'm new here. I have a foto somewhere...)
    Even played with the adjustment of the double feed detection.
    It came to my mind (I read it somewhere, I suppose) that the timing adjusts itself in some way with the feed speed, so I try this and the problem disappeared... just pushing the feed speed from minimun (my defaul then) to one step more!
    I've not used this paper since then, but no problems with the others in this speed.
    Not a very cientific approach, but hope this helps
    • thibaut
      • Mar 2017
      • 23
      • Paco Telescopios
        • Nov 2017
        • 20
        Thank you,
        Yes, just the speed buttons in the machine.
        I also thought it to be related to the timming, but checked it and seemed ok (I could be wrong, no experience)
        I examined the options in TM and was afraid of getting it worse, je.
        In my case, the sheet after master went always ok, and I realized that by default it was setted at speed two, but after the master was made I used to lower it.
        It is a very silly thing, but raising the speed seemed to work for me.
        Good luck
        • thibaut
          • Mar 2017
          • 23
          Originally posted by Paco Telescopios
          Thank you,
          Good luck
