Riso MZ790 error C02-253 Replace Master Roll ~
  • onlygreatcopiers
    • May 2011
    • 41
    So there was a the common issue with the white cog with the screw in it BROKE underneath the TPH and I replaced, but when I put the machine back together it gives me error code C02-253 (or C02-200) REPLACE MASTER ROLL but i have tried 3 different rolls and that is not the issue. I did notice that when it rolls the masters in and then rolls it back out that it goes a little bit further than usual for some reason, then I get the code.
    The tech manual reads that the reset method is Master-making Unit Sensor: OFF -> ON, Master detection sensor: OFF -> ON
    The problem is that I have NO idea where these 2 sensors are or how to turn them from OFF to ON.
    Any help would be appreciated.
    Cheers!
  • 20gaugeO/U
    • 557
    Re: Riso MZ790 error C02-253 Replace Master Roll ~
    I have not had the pleasure of this error code but since you were in the master making unit replacing the gear I'd go back and check for a pinched wire or stressed tie wrap. You are probably looking at testing TM 400, 401, 402
    Hold yellow reset while turning machine on, update firmware, check wire harnesses, etc...
    Good luck
