riso rz 220 stretched mark on paper
  • smiley
    • Aug 2008
    • 616
    good day guys. i have this problem in some of my riso rz 220 i already replace the stripper pads and adjust some angle but this still occurs. please see sample photos thanks.
    there is no glory without sacrifice
  • jermyth
    Riso dude
    • Mar 2011
    • 437
    Re: riso rz 220 stretched mark on paper
    I have seen a few different causes for this. First is often the paper, does it happen with a different ream? Second, impression roller needs replaced. Third, one-way timing gear. There is a tech flash from 2005 about replacing the timing gear, see attached PDF. Good luck.
    • smiley
      • Aug 2008
      • 616
      thanks for the info jermyth. it happen in all reams. but just in news print paper or thin paper type if they use bond 20 gsm or book paper its ok. i will try the one way timing gear that you said.thank you so much.
      • 20gaugeO/U
        • 553
        Probably the Impression Roller under the drum like jermyth mentioned
        • smiley
          • Aug 2008
          • 616
          good day guys thank you for all the response. its the wear impression roller that cause this problem. i replace it and problem solve.
            well the suggested fix did it?
            if SO then PLEASE go and LIKE AND THANK the tech that gave you the advise. This is the only way we can build up our REP POWER, is when someone likes and thanks for our advise.
