Riso FR3950UI.jpgHopefully this can be seen. I'm curious what would cause the duplicator not to print the whole original. The print is about the 30th. I service copiers mainly, this is only the 2nd Riso I've looked at. Thanks!!!
RisoR3950UI
Re: RisoR3950UI
Was this a scan or print? try an internal print if this was scanned, to eliminate the scanner.
Has the drum been sitting long without use? When a drum sits, the screen can clog, causing poor fill issues. See past threads on how to clean a drum. If a different color drum is available, try the same image and compare the resuts.2000 mockingbirds = 2 kilomockingbirds
