Ricoh Priport DX4640PD
  • T911
    • Jun 2007
    • 628
    This one is asking to replace the drum. Can i reset the count in sp mode or does the machine recognize a new drum install and then resets the count? If it can be reset, does anyone know the sp mode to reset the drum count. Thanks
    Re: Ricoh Priport DX4640PD
    if it is possible... the procedure would be in the service manual
      • 37360
      What exact message are you getting? The only thing I find in the user guide is: Drum Unit is not set correctly. The other possibility is you have selected to print in a color and do not have that color of drum installed.
      Otherwise, if you are not a trained Ricoh tech on this specific model, put you hands up and walk away. The drum position sensors are easily damaged and the duplex unit is a mechanical nightmare.
      • ddude
        General Troublemaker
        • 473
        So true.
        2000 mockingbirds = 2 kilomockingbirds
