RISO 3750 drum carriage locked - no drum in carriage
  • patrus
    • Feb 2017
    • 5
    RISO 3750 The drum carriage is stuck / locked -There is no drum in the carriage it is empty. The green light will not come on, so we can't pull the carriage out to load an ink drum.
    We have tried the power off/on and reset button still nothing ?
    Any suggestions or help would be appreciated - Thanks
  • jermyth
    Riso dude
    • Mar 2011
    • 440
    Re: RISO 3750 drum carriage locked - no drum in carriage
    There is a solenoid release that won't actuate without a drum in place. But you can manually release it with a screwdriver, flat blade best. There is a slot just under the carriage. You should be able to insert a thin flat blade screwdriver and release the hook holding the carriage in. If you can't find it, I'll try to find pictures.
    Good luck.
    • patrus
      • Feb 2017
      • 5
      Good luck.
      Thanks I know where that is we will give it a try
        just a suggestion... when a tech here gives you something to try... pleas give that comment a like.... if the suggestion FIXES the issue please give the tech a LIKE AND THANKS.
        this is the way that we techs here gain rep points.
        another nice thing would be IF you plan on using this site for future problems... please DONATE to the site to keep it running.
