The drum goes 1/2 inch past the home position and stops, then throws the e-22 or e-06 error code. Does anyone know how to reset this?
Thanks in advance
Damaged position sensor(s) on the rear frame. You will need to manually turn the drum to home position to remove it. Tab on the rear flange of the drum is most likely bent and damaging sensors. Some of the sensor may be just knocked loose from their mounts. Some of the mounts could also be damaged. Once you have replaced all damaged parts, including the tab, it should be alright. Do not try straightening any bent metal parts.
