SC7700 RP/GR compatibility?
  • Paco Telescopios
    • Nov 2017
    • 20
  • jermyth
    Riso dude
    • Mar 2011
    • 441
    Re: SC7700 RP/GR compatibility?
    The SC7700 is not RP compatible. A SC7900 is. So don't go looking for a GR it's not compatible either.
    The RP is also network capable with at RISORINC-net C card. Or B pending on serial number.
    Good luck.
    • ddude
      General Troublemaker
      • 473
      I may have a SC 7900. Let me check. I have a small collection of Riso controllers that will work in various Risos.
      2000 mockingbirds = 2 kilomockingbirds
      • Paco Telescopios
        • Nov 2017
        • 20
        Good luck.
        Thank you very much, jermyth
        I've seen sometimes a RP3700 selled with a SC7700 so I understood they were compatible. I know compatible is not the same that "can work", so your advice is time-saving.
        Thank you
        • Paco Telescopios
          • Nov 2017
          • 20
          Thank you ddude!
          These are very good news.
          I wait
          • ddude
            • 473
            I have a Riso SC-3500 controller with no cable- this requires a scsi-type cable to connect from the controller to the Risograph.
            I have a SC7000 which may be compatible with the RP series if you have the network card installed.
            I have the network card kit available as well- the Risorinc-Net C p/n S-4094
            I also have a PS7R controller
            I also have a PS7R-9000 controller
            These are both network-based and may work with the RP, although I have no way to document for sure that they will work.
            • Paco Telescopios
              • Nov 2017
              • 20
              Thank you ddude,
              As I told you, I'm not sure if any of this options suits my needs... and my skills!
              Thank you
